hello, I have a strange question: I have an high wing model with large flaps like STOL ones. it flies really slowly despite the weight and size, but I have to deal with the so called P Factor i.e. a drift to right when flying slow with flaps extended and engine to keep the desired altitude..
Easy solved with a flap-rudder mix activated by a switch.
When I need to lose altitude, so engine is lower, no P Factor, so better off the mix switch.
My silly question is: do you think it is possible to turn on automatically the mix when engine is higher than a defined percent? I.e using the throttle stick as the mix switch similar to the engine timer activation? I have a SX 9 V. 1.4
Thanks for reading
Warm regards
Carlo
Vorgeschlagene Themen
Hilfe beim Binden von C3 SX12 mit C2 SX7 | COCKPIT SX | 15 | 346 | 25d |
Klappen auf drei Stufen Schalter | COCKPIT SX | 2 | 515 | Aug. '24 |
Display Cockpit SX | COCKPIT SX | 0 | 544 | Mai '24 |
Cockpit SX (Classic?) Modelle konvertieren zu Cockpit SX 9 | COCKPIT SX | 2 | 285 | Sept. '24 |
Meine Cockpit SX (C2) klebt. Wie beseitigen? | COCKPIT SX | 3 | 142 | 4. Mrz. |
