hello, I have a strange question: I have an high wing model with large flaps like STOL ones. it flies really slowly despite the weight and size, but I have to deal with the so called P Factor i.e. a drift to right when flying slow with flaps extended and engine to keep the desired altitude..
Easy solved with a flap-rudder mix activated by a switch.
When I need to lose altitude, so engine is lower, no P Factor, so better off the mix switch.
My silly question is: do you think it is possible to turn on automatically the mix when engine is higher than a defined percent? I.e using the throttle stick as the mix switch similar to the engine timer activation? I have a SX 9 V. 1.4
Thanks for reading
Warm regards
Carlo
Vorgeschlagene Themen
3D-Druck: Halterung | COCKPIT SX | 1 | 290 | Sept. '24 |
Gasknüppel soll Spoiler bewegen | COCKPIT SX | 13 | 513 | 16. Febr. |
Cockpit sx12 lässt sich nicht mehr laden | COCKPIT SX | 2 | 481 | Jun. '24 |
Reichweite der 2,4-GHz-Anlage beim Wasserflug | COCKPIT SX | 2 | 307 | Aug. '24 |
Multigyro CSX Bedienelement | COCKPIT SX | 1 | 147 | 5. Febr. |
