Hi when I save the model memory from my royal SX in the launcher royal pro dataset folder I can only see the .rop files via the launcher program not via the explorer. I can't see them and not save them in an other library for backup.So for the moment I have model memories that I only can reach via the launcher.(Using Windows 10)
Dear Sir,
at the Royal transmitter you are only able to do complete backups of the whole transmitter (all memories at once).
Best regards
Yes I'm very familiar with how it works. Looong time MPX user.When I said model memory it's the whole TX.I can go to my older computer backup and install the files then I will see the file in the folder and in folder via the launcher, but when I save a memory from the TX I can only see them via the launcher and therefore not save them in another place for backup./lennart Update. If I completely remove the launcher from computer and reinstall it the files in the launcher dataset folder is still there.
Problem solved. The files were in folder ViritualStore, why just those files was stored there I can't explain but in the launcher the files shows in the same place but they are not.I have removed them and now I have a clean launcher./lennart
