I Will use my wingstabi RX with powerbox SRS system and is there any way to get the srxl signal out from the wingstabi RX. The manuals are not the easiest to understand…
Hi, right now it's only possible with the hardware 1.1 which is only available in Wingstabi Rx 12 DR M-LINK and Wingstabi Rx 16 DR M-Link.
You find the hardware 1.1 if there is an SRXL Port on your Wingstabi.
Best regards Michael
Thanks for the answer, you mean the new wingstabi ”evolution” with different hardware...correct?That was pity bacause I have severel of the old ones. Then it has to be one of the RX16 pro without gyro, have a couple of those tooBest regards Lennart
