Hello,
Just received my Wingstabi that I bought from Lindinger, I use Frsky gear and in certain conditions I'm experiencing really violent twitching from the servos! When booting everything is OK, but when transferring settings to Wingstabi, accessing the radio calibration menu, or even just after sometime all channel start twitching, This happens with or without Servos connected, I'm using a Castle BEC and I've tried 3 different voltages. If i disconnect just the receiver from the Wingstabi and connect it again it immediately starts working normal. I have tried 3 different receivers SBUS receivers, X8R, X6R, XM+, and two different radios FRSKY x9d, and Radiomaster TX16S, all using latest firmware.
I use this gear with innumerous flybarless and Gyro units and have absolutely no problems.
Am I doing something wrong?
Thank you in advance for any help you might provide
