Tilslutning af wingstabi blinker ikke men kort efter en bib lyd med ca 1 sekunds mellemrum hvad er galt?US
Wingstabi makes no sound, it must come from your ESC Uffe
Arne
Hallo ArneHave troede with another receiver and ESC okWingstabi does not light up with 6 voltWhatsApp could be wrong?Wingstabi has been Running fine with ESC so farUffe
Do you have taken away the positive pin from the ESC to the Wingstabi if you have a battery connected to the Wingstabi?
Hallo ArneI have tryed to Connect a batteri 6 volt to Wingstabi without ESC and there is no green or red lightWhat Else Can i do?
If you connect this to a pc and check status in Launcher software, you should have the USB dongle that came with your Wingstabi.
