Hi,the recommended settings from Wingstabi Evolution manual says "This has now made it possible for us to define an ideal basic set-up, with which you will
achieve outstanding results with virtually any model."
Basic menu:
Gyro gain offset values:
AIL -> easy Control = 0 / Classic = 30
ELE -> easy Control = 5 / Classic = 35
RUD -> easy Control = 25 / Classic = 55
Advance menu:
Differential gyro gain adjustment: Is this same as Derivative gain in Launcher??
AIL = 18
ELE = 16
RUD = 14
Adjusting the Direct values in the Classic system to 80, in flight mode 2 and 3 or also 4??
Defining the Stop functions as: in flight mode 2 and 3 or also 4??
AIL = 4
ELE = 2
RUD = 2
The gyro sensor’s low-pass filter has been reduced to 20Hz.
Optimised damping” regulatory mode is this the Dynamic Integrator size tick box in Launcher?
The default for gyro suppression is set to 200 for the Easy Control and
Classic. in flight mode 2 and 3 or also 4??
Are these recommended settings only in damping mode (flight mode 2) and in flight mode 3. If you hower over settings the default says these numbers. But in flight mode 4 there are other defaults numbers.
Sincerely Arne
