Hello Forum members.
I have a Wingstabi 7 Classic paired to a Mutiplex RX-7-DR M-link receiver and utilize a Royal Pro 16 (firmware version 3.60) transmitter.
The Wingstabi Advanced manual states the following on page 4: "All WINGSTABI versions with or without integrated M-LINK receiver generally accept up to 16 control channels on the input side (or even 18, depending on RC system). On the output side, 7, 9, 12 or 16 channels (the more channels the higher the transfer rate) are available for analog or digital servos, depending on the version"
This statement in the Wingstabi Advanced manual left me with the impression that my Wingstabi could accept up to 16 input channels. I was able to successfully assign the following controls to the Wingstabi output channels: 1) Aileron, 2) Elevator, 3) Rudder, 4) Throttle, 5) Flight Mode, 6) 4th Flight Mode, 7) TrmElev. However, when I assign additional functions in the transmitter (for example, TrmAiel, TrmRudd, a slider to adjust gyro sensitivity) to transmitter channels 8, 9, 10, 11 etc., the Wingstabi does not recognize them. Is this a normal behavior of the Wingstabi 7 Classic?
Is there a "work-around" solution that would allow me to assign transmitter channels and assigned functions (in particular TrmAiel, TrmRudd, and a gyro gain slider) to channels 8 and higher?
Best Regards,
Marcus
