Sounds good, will this work with the RX7 and RX7DR?
What would be good is if we could renumber the receiver outputs so we could say gang together two 7 channel receivers to get 14 channels, this would say be useful on larger aircraft where dual receivers are not only good for diversity but also you could attach one receiver to the wing to control all wing servos (ailerons, flaps, airbrakes, retracts etc) and then have a 1 wire connection to the 2nd receiver in the fuselage which would control those servos (Elevators, rudders, throttle, choke etc)
I will definitely give it a try with a flight controller,(CC3D) hopefully I will be able to use the flight controller for the ailerons, elevator, rudder and then the receiver connections for throttle, retracts etc.
