I would like to submit to you a problem with the operation of the Liposaver #85421.
Symptom: Total voltage of the power battery on address 3 on telemetry is incorrect in case of separate power supply to the receiver.
Equipment used :
- LIPOSAVER #85421 software version 1.02
- Multiplex RX7 DR Mlink #55811
- Multiplex PROFI TX9
- ESC Roxxy BL755
- switch Hitec
- RX-Battery ENELOOP 4 elements NiMh
- Power Battery Roxxy 4S/2600
TESTS :
1) Configuration 1 : Without RX-battery: the telemetry values are correct on address 3, total battery voltage 16.4V.
2) Configuration 2 : with RX- battery 4.8V connected to RX7 and (+) wire disconnected on ESC cable to port4 of RX7 : telemetry value address 3 (total battery voltage) is not correct: the nominal value divided by 2 (8.7V) ;
3) All the programming options of LipoSaver with MPX Launcher have been tested without success in configuration 2.
4) Another LipoSaver were used with same wrong results on configuration 2.
Question :
is it possible to receive the correct value of the total battery voltage measured with the LipoSaver in the configuration 2 with separate receiver battery?
If so, can you tell me the correct way to connect or program the LipoSaver for this purpose?
Thank you for investigation and your response.
Stephan Thoumsin
