I recently bought a EasyGlider 4 in kit form from Multiplex as I already had a similiar electric motor as recommended in the construction guide.
However, now when I tried to moutn the motor in the motor mount, I realise that the holes in the motor mount do not align with the motor. On the motor mount there are 4 holes equidistant roughly 24mm apart, while the motor has two holes at same distance, while the other two are closer. My question is:
1.Mounting the motor with two bolts is adequate, or
2. Drill two additional holes on the motor mount to align all the holes with the motor
