Meanwhile after my own testing and programming the radio I can answer to myself Please correct if not the right information.
Flight time (motor and flight time) announcements ""1 minute, 2 minutes " etc. starting counting from 0 sec when I launch the glider, also not as count down only
No possible, automatic announcements only possible with countdown
Reseting timers from a switch after landing
Not possible,only through touch screen separately for both timers
2.When using telemetry (Unisense):
Altitude announcement by pressing the side left or right side small button I can hear " 75 m" etc
Not possible, only one switch can be selected for all telemetry announcements
Battery capacity announcement by pressing left or right side button like " 1450 Mah"
Additionally "sensor x" is useless to mention before the actual value, would be better " altitude 75 m etc: if only the value not possible to mention
Possibility of turning the vario sound on/off from one of the switches
YES.
MIXERS:
Having flaps and ailerons in positive/neutral/negative setting with left side 3-step switch and having announcements "thermal/cruise/acro" in separate settings
YES
When flaps and ailerons are in negative setting only, flaps move up with ailerons. In other positions flaps don't move with ailerons ( except naturally in butterfly at landing)
YES
In motor plane:
Flaps move with ailerons up and down but when flaps are lowered for landing with a bottom roller/or switch, they are not following ailerons and working only as flaps.
YES
Possibility to use flaps for landing with 3-position switch instead of roller
YES
Hearing announcements like every 30 sec when flaps are down " flaps down"
not possible, only once when flaps activated
ps. Adding own sound files with Launcher is easy which is a clear benefit for Cockpit and generally MPX Launcher SW is made simple and easy to use and very stable
Even new Cockpit is easy to program and a modern radio, there are some small but important improvement points in SW in to reach a perfect set-up for my purposes. Maybe there will be a SW update at least to have each telemetry value announcement possible to be set to any switch which I would appreciate at most.
Jussi
