I went to check out a model that had not flown for several years, and found that it was switched on and the battery completely discharged. With a new battery the receiver would not recognise the transmitter, I tried the channel search procedure and the receiver went into search mode but could not find the transmitter, a Cockpit Sx 35mhz on channel 67.
The receiver connects to launcher and I reinstalled the software, v 1.26, but it still will not find the Transmitter. Any ideas or is the receiver usless?
Note it is not the transmitter as I successfully set up another synth Rx.
Thanks
