We were having a problem with the stick position and the percentage of movement calibration in our MPX Royal Pro SX16 TX.
We have deleted all our model memories and reset our TX back to factory settings. After recalibrating our Royal Pro SX16 to factory settings, through the MPX Launcher we find the stick position and the percentage of movement on the throttle calibration graph in the TX to be the same.
When we create a new model using the Basic or Acro Template and the Power assignment, we find that the stick position and the calibration graph have changed.
The throttle stick moves through it's full function, but the graph in the TX only moves from position 3 to full throttle i.e. 50%.
The throttle servo in our aircraft only has 1/2 (50%) of it's full travel.
No other factory settings have been altered or entered and the calibration to factory settings was carried out with all sticks, switches, trims and sliders in their central positions.
We also have the same issue when using the MPX Muliflight Simulator.
Regards,
Stefan & Annette
