Got a friend to translate which ill post and also FS replied on facebook. I am sorted now thank you. The thing that got me was the word corona meant light in the middle. This is translation incase it helps someone else
You need to run the program on your PC. You can download the PTXadj4.exe program for free - just visit the Multiplex website and look for 'Downloads / Software'
- The donors are adjusted as follows:
6.1 Turn on the transmitter and connect to your PC (Profi TX is recognised as a game controller)
6.2 Bring all sliders (middle and side) and the stick in to the middle position including side sliders
6.3 Start the PTXadj4.exe program ('abgleich' (adjustment) will flash in the display)
6.4 Bring all sliders to the end position until the Corona ( middle light ) comes out and then bring them back to the centre position. Also move the stick to the opposite corners, wait until the Corona comes out and then bring it back to the centre position. ..... I did each slide in turn moved it until the middle light came on when off moved back to centre. You must do every slider and both sticks.
6.5 Switch off the transmitter. Disconnect the USB cable. Alignment is complete. When switched on, the transmitter returns to normal operating mode.
Tips
If the transmitter goes into adjustment mode when its switched on again, not all end stops have been recognised. In this case switch off the transmitter, bring the slider and stick in to the middle position again, switch on and proceed as described from step 6.4.
If for some reason you cancel the adjustment (eg if you don't have all the sliders in the middle position), switch the transmitter off, put everything in the middle position, switch it on and proceed as described from step 6.4.
If you want to do the adjustment again (you can see in the servo monitor that an encoder wasn't exactly in the middle) just repeat step 6.
Good luck! 🤞
l
