I tried to pair my Cockpit SX (7 ch, older model, yellow) with Rx9 DR receiver which was working ok with my royal sx16 in Funcub.. It got paired ( led was blinking after pairing lilke it should be) .
However, servos in Funcub are moving not ok all the time; movement is not smooth, sometimes some servo moves itself, servos movement is like there would be disturbances in radio link; Servos don't follow the sticks movenent precisely.
Pairing has been done always in same place, no wifi etc possible disturbance factors which could cause these problems.
Then I tried to pair Rx 7 light ; same problems.
The last paired receiver was Rx 7 dr and with this servos work as they should.
Same receivers work ok with royal sx 16.
The strange thing is that in planes where I have other receivers paired earlier with Cockpit Sx, they work ok.
I even tested other servos with the problem receivers and cockpit; same result; servos do not work ok.
Rx voltage was coming either from rx battery or ESC with BEC
So any ideas I have these problems with Cockpit Sx and Rx 9 dr and Rx 7 light ? It feels like the wireless link between the radio and these two receivers is not working ok after pairing procedure. Cockpit has always worked ok for many years,never had similar problems with my MPX radios before.
Jussi
