Hello!
If I understand you right you are an experienced modeller and you are much more in saoring than in powered modeles. But you can read this on the cover of the manual:
BK / KIT Solius# 21 4264
vorgesehen für den MULTIPLEXBrushless-Antrieb # 33 2660 / 33 3660
Designed for the MULTIPLEXbrushless power set # 33 2660 / 33 3660
Models like the Solius are designed and optimized for the powered version and any modeler who claims expierence in this field should know that running a kit like this as a pure glider will need some modification as the weight of the missing parts (motor, accu, prop, ESC ...) have to be compensated. You cannot really expect any reduction in weight - eventhough the manual says that 200 g are possible.
By the way - and I am not a very experienced glider pilot - most users put in additional weight for appropriate flighing in wind and at slopes.
with regards
P.S. If you are English, British or American you let miss all forms of politeness - and I always thought your are so keen on that. The forum is not MULTIPLEX and we deserve a certain politeness even if you are disappointed with a product. Here you are mainly talking to customers (eventhough mostly infected bay the MULTIPLEX-virus) not exclusively to MULTIPLEX-representatives.
