Hier die Daten des ROXXY C2834 850kV Brushless Outrunner Motor
14 polig
ROXXY® BL Outrunner
14 pole BL external rotor motors
ROXXY-BL are lightweight, powerful and low-speed 14-pole BL motors with high torque, specially designed for LiPo batteries. Due to their design, external rotor motors can drive large propellers without gears. This makes them ideal for direct drive and perfect for 3D flying with Depron models or large scale models.
Features
- High efficiency due to maximum copper fill ratio and use of high quality neodymium magnets.
- Smooth running due to large precision ball bearings
- Mounting possible on both sides
- Exchangeable motor shaft
Third ball bearing
The ROXXY® -BL external rotor motors of the D and CA series are equipped with triple ball bearings. To improve concentricity and precision, a third, so-called thin-ring ball bearing is used. This prevents the motor bell from twisting under load and ensures smooth motor running.
- Designation: Roxxy BL Outrunner C28-34
- Diameter: 28mm
- Length: 34mm
- rpm/volt: 850
- Voltage range: 7-15V
- Load current 5min/120°C (A); <17A
- Load current (max 60sec): 22A
- Continuous power (W) (5min/120°C): 250W
- Max. Power (max. 60sec.): 340W
- Weight: 72g
- Shaft diameter: 4mm
Application area
- E-Sailor: up to 1100g
- Scale and Sport: up to 800g
- Aerobatics and 3D: up to 550g
Gruß macsimu
