Hello!
As I have written so many times by now. Butterfly depends on the spoiler function. You have to asign the aileron servos to ail+ and the faps to flapin+ and the you have to give in the right ratio for spoiler in the mixersettings. Don't forget the elevator compensation in elev+ and again it is the ratio spoiler you habe to set at about 5 % down for a start.
This is the normal way for setting butterfly in a MULTIPLEX-transmitter. You mixers may have slightly different names because my terminology is taken from the ROYAL SX and ProiTX. But the philosophy is basically the same!
so long
