Ok, can you also do so that when you activate throttle for the first time, motor time starts to run and also the total flight time like in Cockpit ?
With Cockpit you can activate with throttle stick also the total flight time timer and it does not stop until you switch it off from the round menu button.
Also no need to use any extra switch for total flight time timer, throttle switches on two timers.
