New to this forum with a question on a legacy transmitter.
When doing the adjustment of the throttle stick, including the 3 way switch, i Cannot get a correct operation of the electric motor of original MPx merlin power set.
Bottom position of stick corresponds to middle position, indicated on screen with the “dot”, moving stick to top position shows stick at 100% with the “arrow” pointing upwards. The 100% down position is only possible when trim is also moved fully down.
In any case, when motor eventualy starts running, the idle speed is way too high. In fact, i can not even properly bind the esc if i try to re-do so
Already tried changing and disconnecting the 3 way switch with similar Result.
Software or hardware problem?
