Hello Frank,
At First I opened the servo Monitor. When I moved the trim Levers e.g on rudder, aileron and elevator there was no movment on Channel 1, 2 and 3. But the Bars on 7, 8 and 9 were moveing.
Then I went into the menu and you are right that trim was set to zero on Ruder, aileron and elevator. I changed it to 1,5 as it is the normal setting on the old Royal Evo.
Back tothe servo monitor all Bars were moveing correct on 1,2 and 3. Together with the Model it is working also correct.
But still the Bars on 7, 8 and 9 are moveing.
At the end I do Not want to have Signals from the Transmitter which I do Not Need.
Under the servo menu there are three Lines with aileron tr, Elevator tr and rudder tr. If I Open this it Looks the same as if I Open just aileron, elevator and rudder.
Still i do Not find the menu Point to Switch 7,8,9 of.
Have you used the Single trim Funktion.?
