I have 7 channel Cockpit 2.4 Ghz (older generation from 2014) where the transmitter battery voltage value does not stay stable; it varies suddenly from for instance 8.18 V to 7.93 volts and then jumps back to 8.10V within seconds. Battery is brand new (original 6/2100 mAh MPX NiMh battery) . It did the same with old battery. This feature has come to my radio lately so it has not been always like that.
Is this a typical for older Cockpit radios ?
I suspect that there is something wrong with the circuit which measures the voltage of the radio.
In practice it is a problem when battery is low and it is difficult to know if it is really empty if voltage display varies between 7.3 V -7.1V and low battery alarm is at 7.1V.
Regards/Grusse,
Jussi
