What are the possible causes for the throttle failing to respond to commands?
Solution:
You might accidentally have activated the EMERGENCY throttle OFF switch.
Check in the SETUP / ASSIGNMENT / SWITCH menu whether there is an asterisk (*) after the switch name in the EMERGENCY throttle OFF line.
(*) means: function active
