When I press return button to check max and minimum levels on all sensors I discovered that signal level could be as low as 30% on minimum at seconds after I turned on the receiver. Then its imposssible to check if I have lets say 50% during flight. It will always show the lowest level from when I turned it on. Is there a reset function I can use to start over before I take off?
