Hi, any ideas to have clever wing cable connectors for Funcub XL and Multilight ? There is two different outputs needed for wing lights if I want to use 3-stage switch in TX for switching lights separately on/off (there is 2 x win tip LEDs and separate landing lights). I noticed that male servo jack would fit in one empty hole close to aileron and flap servo connectors in the wing. Is it possible to use standard 3-pole servo connector so that I would connect all three minus to one common ground and connect the two separate plus cables from two wing tip and landing lights to two own poles ? Using so I could use only one cable for all wing lights.
