Yesterday I accidentally left my 35mhz Sx C2 switched on and the battery went flat. The battery has taken charge and holds voltage when being discharged on the charger at 0.5 amps. But when I switch on the Sx the blue light comes on but the screen is dead. Have I damaged it irreparably or is there an easy fix.
Just fitted this battery into an older Sx (C2) with a faulty rudder stick and the set switched on fine, so it's not the battery. If there isn't an easy fix for the newer set, I'll just have to swap the faulty stick unit out.
