Hi, When I run the Wingstabi transmitter calibration and set the end point in the green area I can do this perfect with high dual rate settings. If I switch to low dual rate the end point will naturally not go green. Is this OK for low rates as long as full rate is in the green area?
Thanks
Sincerly Arne
Norway
