Have a look at THIS document.
I am not sure what you mean with "program data", but if it is the firmware version, this document suggest that even for the 16 Pro and 16 SX it shows ROYALpro12 as the transmitter type.
As for the manual, I would suggest that you upgrade the transmitter FW to version 3.56. This will make it a SX version, so you can download the manual HERE.
All this assumes you have a 2.4 GHz version. You may also have to update the 2.4 GHz module (with yet another USB cable, #85149).
Regards,
Max.
