I have normally throttle in left stick and also motor time switch in this same stick.
However, in one certain thermal glider I use motor from slider F (instead of channel 4 I have connected ESC to channel 7 in receiver and channel 4 is empty) and I would like to have also motor time switch in this slider.
If I change sum timer in switches menu from left stick to slider F , it changes of course motor timer also to slider F in all other gliders which use the same Glider template.
Is there any way to have motor timer switch in different places in different gliders if needed ?
Or should I do some other changes to set-up ?
I could have motor actually in left stick and in some switch located close to right stick at the same time. Using slider F is done only to have left hand free for launching while operating ailerons+elevator and throttle with right hand. (= Throttle use with right hand through slider or switch would be needed only for launching and first climb)
Could this be achieved with flight bases for instance?
-phase start; throttle in slider F or in some switch
-phase nornal; throttle in left stick
- in both cases the motor timer would need to run if motor would be on
Regards,
Jussi
