Hi
I have activated a electro motor security by using the throttle cut function available by default on the H press button.
I had to configure the function to use the H button as a two permanent states, instead of activating only when pressed.
It is workng well but, when I switch ON my radio the security is descativated by default and I have to press the H button once to get the safety activated.
Is there a method to have it activated by default when I switch on my radio?
Thank
Jean-Pierre
