Hallo, kann man den Digi-Einsteller für die Empfindlichkeit des Wingstabi verwenden. Wenn ja wie muss ich das einstellen.
von welchem Sender redest Du?
Gruß,Manfred
Hallo,der Sender ist eine Profi TX.
This was discussed here http://technikforum.multiplex-rc.de/t/digiadjusters-as-controllers/2128, hope this helps.
this is my solution for this problem. I have prepared mix with two fixed inputs, switchable with FP switch. In Mixer menu assign fixed value to a 3-D digi-adjuster (right for gyro phase 2 and left for gyro phase 3, phase 4 i do not use). So you can use the 3D digi-adjusters for gyro gain settings during the flight.I use Royal SX16, but i think that principle is the same for the Profi TX.
Mysak
